May you tell me what is the name of this black box on my MK4 Fuel injection Pump because I can't find it anywhere on Internet or in my VW Bentley Book! It is a seal behind this box that leak? Is it available and what is the part name?
I will need a special tool for the triangular screw? Is it a 7 mm and is it the same size than the screw on the top of the pump, it seems not by eye?
Thanks in advance.
OK, after searching after a member, 1854sailor,, that told me it was related to the Quantity Adjuster wiring, it seems that I will have to change the 2 Quantity Ajuster seals.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
