Do I need to prime/bleed through vcds or can I simply just start the car after switching the filter out?? I don't have vcds available and want to do it in driveway.
Figure I should share that my 6/2013 build NMS does run the in tank pump for 2 seconds when key is turned to on, this was verified when I changed my fuel filter I held the top over the empty filter can while wife turned on the key. it filled it 1/16th the way in under a second- quite the mess btw
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
