jrock
SOLD - After purchasing a Cruze diesel I’m now ready to part with my cherished 01 Jetta. I have done most of the maintenance myself. What work I haven’t done myself has been done by Brian Hague (aka Alphaseinor). Some work early on was done by the local VW dealership. I have used this site as my number one reference for all things TDI and have performed all maintenance to the specific direction of this site.
Overview:
2001 VW Jetta TDI GLS
5 speed manual transmission
In dash CD + CD changer in trunk
2 working key fobs and valet key
Original owner’s manual
222,000 miles
The car is mechanically sound, I’ve recently dumped more cash into the car than the asking price. Example: Resealed fuel pump, new alternator, new battery, new AC compressor, blend door.
Pros:
Fuel mileage has been 48 -50 (52 when trying)
Many new parts (OEM)
Drives great
Meticulously serviced
No rust
No CEL
Original clutch has no slippage
Oil has always been Rotella T6 and filter has always been MANN
Cons:
In some areas the clear coat is peeling off
The fabric on the door panels is loose and coming off (passenger door)
Door dings
Wheel emblems have come off on the rear wheels
Broken glove box door handle
The car was involved in a minor rear-end collision in 2005. The body shop used OEM parts and did a great job. 11 years later it’s still fine.
History:
Date Miles Description
9/6/2016 222,300 038 903 024GX, Alternator
9/6/2016 222,300 2 467 010 003-000, Injection Pump Seal Kit
8/27/2016 222,000 Replaced battery OEM VW
4/16/2016 220,042 Changed - Engine Oil, Engine Filter, Fuel Filter, Dust Pollen Filter
2/13/2016 219,232 Vacuum Hose Kit for ALH
7/20/2015 212,992 Replaced AC compressor, expansion valve, drier, flushed system
7/17/2015 212,850 Repaired blend door with metal
1/24/2015 210,037 Replaced Thermostat (A4)(A3)(B4)(B5.5)
1/24/2015 210,037 Changed - Engine Oil, Engine Filter
2/8/2014 200,022 Changed - Engine Oil, Engine Filter, Fuel Filter, Dust Pollen Filter, Air Cleaner, Brake Fluid
2/8/2014 200,022 Changed Transmission Fluid
5/17/2013 191,234 Replaced Changed Glow Plug [Beru] GN855 X 4
5/17/2013 191,234 Replaced Glow Plug and Harness Kit
5/17/2013 191,234 Diesel Fuel Hose (3mm ID)
4/12/2013 190,086 Changed - Engine Oil, Engine Filter
10/22/2012 184,196 1 x Coolant Temp Sensor Green [OEM] 4pin w/Seal & Clip (A4)
9/16/2012 183,000 Yokohama YK580 195 /65 R15 91H SL BSW X 4
6/17/2012 180,005 Changed - Engine Oil, Engine Filter, Fuel Filter, Dust Pollen Filter
8/23/2011 170,130 Standard Alignment
8/15/2011 170,034 Changed - Engine Oil, Engine Filter
8/6/2011 169,414 Timing Belt Change. All rollers, tensioner, cam seal, water pump, Timing Belt, Serpentine Belt
8/6/2011 169,414 VNE 4575, Strut Assembly (Bilstein TC) X 2, BNE-2942-BE, Shock Absorber X 2
1/11/2011 163,507 Replaced battery
8/31/2010 160,042 Changed - Engine Oil, Engine Filter, Fuel Filter, Dust Pollen Filter, Air Cleaner, Brake Fluid
11/1/2009 150,045 Changed - Engine Oil, Engine Filter
10/3/2009 149,088 1 x Ceramic Front Brake Pads (A4), 1 x Ceramic Rear Brake Pads (A4)
8/18/2009 147,555 Bosio PowerPlus 357- Set of 4 Nozzles
1/4/2009 140,083 Changed - Engine Oil, Engine Filter, Fuel Filter, Dust Pollen Filter
3/22/2008 130,553 Standard Alignment
2/23/2008 130,131 Changed - Engine Oil, Engine Filter
4/21/2007 122,514 Goodyear Assurance ComforTred Touring 195 /65 R15 91H SL VSB X 4
1/5/2007 120,015 Changed - Engine Oil, Engine Filter, Fuel Filter, Dust Pollen Filter, Air Cleaner, Brake Fluid
11/4/2006 117,969 Replaced Changed Glow Plug [Beru] GN855 X 4
3/9/2006 110,034 Changed - Engine Oil, Engine Filter
10/4/2005 104,888 Replaced oil feed line
10/4/2005 104,888 Replaced strut bushing
5/13/2005 100,123 Changed Transmission Fluid
5/10/2005 100,037 Changed - Engine Oil, Engine Filter, Fuel Filter, Dust Pollen Filter
8/3/2004 91,709 Replaced Air Mass Meter (06A906461X)
8/3/2004 91,709 Timing Belt Change. All rollers, tensioner, cam seal, water pump, Timing Belt, Serpentine Belt
7/6/2004 90,065 Changed - Engine Oil, Engine Filter
TDI Club members only: I will throw in 6 MANN oil filters and 1 cold front.
Overview:
222,000 miles
Pros:
Drives great
No rust
No CEL
Cons:
Door dings
History:
