owr084
On Wednesday I notices some wispy smoke coming up from the cowling. After pulling over and popping the hood, I discovered it was coming from the positive cables on the battery. The smaller diameter cable going to the fuse block was smoking and melted/burned about 2" of insulation. The clamp heated up enough to melt some of the plastic surrounding the battery post. the larger cable going to the starter showed some slight discoloration, but may be ok. I suspect it was caused by the bolt holding the fuse block cable to the clamp came loose causing a high resistance and the resulting heat and smoke.
Questions: I called 1stVWparts and they said the only cable they could find for it was an "assembly" for $190 (and only 11 in country). I don't have th exact part number. Does anyone know (Oilhammer?) what exactly this assembly entails? Is it just the starter cable or does it include the fuse block cable or is there another part number for just the fuse block cable alone?
Shot of the fuse block cable:
Shot of the cables and battery post - note the heat damage to the surface around the post itself. I have not checked yet to see if the battery leaks at that point now..
