Okay, heres what i got back
KW1281Test 0.50-beta (
https://github.com/gmenounos/kw1281test/releases)
Args: com3 9600 17 DumpBeetleMem 14336 2048
Opening serial port com3
Sending wakeup message
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Protocol is KW 1281 (8N1)
ECU: 8N2920980A KOMBI+WEGFAHRS. M73 D09
Software Coding 00444, Workshop Code: 00000
Usage: KW1281Test PORT BAUD ADDRESS COMMAND [args]
PORT = COM1|COM2|etc.
BAUD = 10400|9600|etc.
ADDRESS = The controller address, e.g. 1 (ECU), 17 (cluster), 46 (CCM), 56 (radio)
COMMAND =
ActuatorTest
ClearFaultCodes
DelcoVWPremium5SafeCode
DumpMarelliMem START LENGTH [FILENAME]
START = Start address in decimal (e.g. 3072) or hex (e.g. $C00)
LENGTH = Number of bytes in decimal (e.g. 1024) or hex (e.g. $400)
FILENAME = Optional filename
DumpCcmRom
DumpClusterNecRom
DumpEeprom START LENGTH [FILENAME]
START = Start address in decimal (e.g. 0) or hex (e.g. $0)
LENGTH = Number of bytes in decimal (e.g. 2048) or hex (e.g. $800)
DumpMem START LENGTH [FILENAME]
START = Start address in decimal (e.g. 8192) or hex (e.g. $2000)
LENGTH = Number of bytes in decimal (e.g. 65536) or hex (e.g. $10000)
DumpRB8Eeprom START LENGTH [FILENAME]
START = Start address in decimal (e.g. 66560) or hex (e.g. $10400)
LoadEeprom START FILENAME
FILENAME = Name of file containing binary data to load into EEPROM
MapEeprom
ReadFaultCodes
ReadIdent
ReadEeprom ADDRESS
ADDRESS = Address in decimal (e.g. 4361) or hex (e.g. $1109)
ReadSoftwareVersion
Reset
SetSoftwareCoding CODING WORKSHOP
CODING = Software coding in decimal (e.g. 4361) or hex (e.g. $1109)
WORKSHOP = Workshop code in decimal (e.g. 4361) or hex (e.g. $1109)
WriteEeprom ADDRESS VALUE
VALUE = Value in decimal (e.g. 138) or hex (e.g. $8A)
Sending EndCommunication block
Args:
COMMAND =
ActuatorTest
ClearFaultCodes
DumpCcmRom
DumpClusterNecRom
MapEeprom
ReadFaultCodes
ReadIdent
ReadEeprom ADDRESS
ReadSoftwareVersion
Reset
Am i still supposed to use the BeetkDumpMem command?
