I'm about to replace my four wire glow plug harness on my 2002 and was thinking about just splicing it together at the top. Has any one done this and do you have any tips or do ya think I should do it the old fashion way?
think with these that's how it's done, some years can;t remember what ones it started at but you can follow the wires and they might come to a connector near the firewall somewhere if I recall
It has a four pin connecter at the fire wall, but I heard it's a pain in the @$$#%$%$% to fish out all the wires. Thats why I'm thinking of splicing it at the top.
Don't splice and don't fish out any wires!! All you need to do is cut the old harness where it dissapears into the mass of wires. Then disconnect the old harness at the firewall and plug in your new harness. At the firewall you can cut away the old harness. The wires for the new harness can be attached to the outside of the bundle of wires where the old wires run with the use of nylon ties.
You need to remove the battery, battery tray, and some of the various plastic covers covering the wiring.
The real cutting is all the cutting of the electrical tape and the occasional that bundles all the wires of the GP harness with other wires. It is tedious work with a razor blade.
Nope. Don't do any cutting of the wire bundles. Just use nylon ties to attach the wires of the new harness to the outside of the bundles. Leave the wires to the old harness inside the wire bundles. I've done it. It only takes a few minutes to install a new harness on TDIs with the four pin connector.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
