Do you sill get full function of the remote for the trunk, doors and windows?I've removed the RFiD tube and siliconed it under the plastic trim piece near the ignition switch. Then any correct key will start the car.
That's ingenious.Yes,FOB is fully functional. The reason this works is the RFID is separate from the FOB functions. With the RFID in a fixed position near the ignition switch the immo ALWAYS recognizes that there is a good key.
In reading that it seemed maybe a bit unclear.The key went for a swim with my son when he flipped the canoe, and drowned. It's at the bottom of the lake
If you have a key with the button fob... Behind the blue vw emblem theres a small screw.. The plastic will come apart much easier if you take this screw out youll see the rfid in there after that,see previous post for more detailsI really like the idea of siliconing the rfid chip near the ignition switch. However in looking my key over I don't see any obvious marks or plugged holes that would tell me where to look for this chip and would rather not have to destroy the whole plastic piece trying to find it. Can anyone explain a little more specifically just where it is imbedded in the plastic? Or even better post a good picture of where to find it?
Sort of hold it with your fingers where you think it will work. Then turn the key to the ON position. If it's not in the right spot you'll immediately get the immo symbol on your cluster. Takes a bit to find just the right spot.Thanks guys, found it now. Soon as we get a warm day here I'm going to try siliconing it near the ignition switch.
I had purchased a Beetle that only had 1 good key. I had a parts car with 3 keys. I swapped out the parts car ignition switch,door and hatch into the 1 key Beetle. By placing the RFID chip next to the ignition. I now have 3 funtioning keys. Call the dealer and ask what they charge for 2 more keys that are programmed?May I suggest a different approach here? Instead of just gluing the RFID capsule to the steering column, why not take your new key apart and replace its unprogrammed chip with the one that works? That way, you're not defeating the immobilizer. Just my 2¢.
And a car that someone with a slide hammer and a screw driver can steal in a New York minute......I now have 3 funtioning keys...
