Tyril
Late last night I was cruising down the turnpike doing 80-90mph average. Every now and then I would notice a dull flash coming from my instument cluster. Driving at that speed, watching the road, and staring at cluster wasnt easy, but I managed. I finally discovered that the left turn signal indicator was flashing erratically. At first I thought it might just be catching some light off of someones headlights, but quickly ruled that out. I tried playing with the turn signal arm, thinking that maybe it shorting out. Nope, tried right and left signal, both worked fine. Now, when I say flashing, I mean strobe like, far from the normal "blinking" interval. Occasionally, it would also just stay on steady for up to 3 seconds at a time. I also noticed that when it was "flashing" I did not hear the normal relay clicking noise.
My girlfriend was driving behind me during all this, she said the actual left turn signal light was flashing erratically, so It was more than just the indicator light.
I can think of two explanations - A relay might be going bad, or....
This theory is a bit out there -
It seemed to act up more frequently when I was near / passing tractor trailers. I know a lot of truckers boost their cb radios to insane power, and also overmodulate. If any of you have ever used CB radios before, Im sure youve noticed that you can sometimes interfere with other electronics, ie, you can hear your voice on nearby TV's and stereos.
I wonder if somehow a wire was the same length as the wavelength (or a mutltiple of) they were transmitting at. I believe that it is possible that their conversations were causing a voltage to be induced in my car wiring, thus causing the relay to fire. I might have been experiencing a visual representation of their conversations.. hrmm
Or maybe it was just another VW electrical gremlin
