gutts
Hello All
Before I started I checked the timing with vag com . The timing was advanced and the cloud was perfect.
I am doing my timing belt . It has been a long time since I’ve worked On this car . I find I am relearning things . I have locked the cam . I have the pin in the IP . I have locked the crank . I cannot see a TDC mark on the flywheel. I can’t remember if , when I replaced the flywheel if it had a mark .
When I locked the crank the bolt holes on the crank were slightly twisted in the slots .
What would be the best way to absolutely verify that the piston is absolutely at top dead center , short if pulling the head ?
2002 5 speed
2002 5 speed
