jakej78b
Hi everyone! I've had my good ole jetta since I bought her at 220k miles. Engine currently has 250k miles. It's had the low oil pressure problem for roughly 25,000 miles. Shortly after I bought it, perhaps after the first oil change I did... It started intermittently throwing a oil light and blaring the alarm at me. After a while I noticed the alarm would only come on under 2000 RPM and only if the engine had a load on it. I changed the oil pressure sensor sending unit. I changed the oil pump. I changed the oil. I use VW 502 rated 5w40 synthetic oil, always. I tried adding lucas high mileage oil stabilizer in my oil... no effect, alarm continued to blare. I've been talking with Anuthee from KermaTDI trying to get the bottom of this problem because I want to get a VNT-17 in the future, but not until I've resolved my oil pressure problem. I recently pulled the valve cover and pulled the cam bearing caps on bearing #1 and #2, pictures are below... Any ideas? Any input is highly appreciated on this matter.
Car is a 2001 Volkswagen Jetta with a 1.9 ALH engine and an O2J 5 speed transmission, fully stock with a VNT-15 turbocharger. The turbocharger is not making correct boost (it is underboosting) and the turbocharger makes weird squealing noises. Could the turbocharger (hopefully) be the cause of low oil pressure? What else can I do to diagnose this issue?
Oil pressure was measured with a mechanical gauge to be around 70PSI at idle while cold, then the pressure dropped as the engine warmed up to around 7-15PSI, depending on engine load and RPM.
