faul713
I have a fan problem that has me stumped, 2005 New Beetle, BEW and 6sp DSG.
Key on, Engine off, AC/interior fan on...the fans work fine. Turn the engine on and they shut off. Then the compressor will cycle with the high pressure shut off sensor. If the ambient temps are around 80 degrees F or so all works fine. Once ambient temps start climbing over 85 or so the fans will no longer work with the AC. I can also turn the fans on with VAGCOM.
All engine and air temp sensors seem to be working fine and agree with current weather conditions, which is hot. I am in Phoenix, AZ.
The fans will also come on and work properly when the engine temps warm up.
The car has had the problem for quite a while. I did replace the fan control unit a while back but it did not fix the problem. I cut the old one open and it looked ok, that is nothing was smoked and the relays looked good.
