LokiWolf
I have not had a failure personally. I am planning on doing a swaybar replacement soon, so it concerns me. If there are aftermarket options that are better, I would do it at the same time.
If I was to do this all over again and know what I know now(40/40 hindsight) I would have installed the Neuspeed links at the same time. Best of luckI have not had a failure personally. I am planning on doing a swaybar replacement soon, so it concerns me. If there are aftermarket options that are better, I would do it at the same time.
Would you mind telling me what part number for the front pieces? I've narrowed the search down to "Tie Rod Ends" but that's all.This is random. I'm glad I found this thread. I've had the front end clunk but have yet been able to diagnose. I'm at 60k.
Under similar conditions, I've had an occasional clunk from the rear since 10k. The dealer was unable to diagnose, but noted it. I doubt they'll replace them now, and to be honest, it's not wort the hassle when I could do them at home in a couple of hours.
FYI, the more rugged Moog parts are on Rock Auto for about 20-25 a corner plus shipping.
Thanks to OP for posting.
Kyle
I say go now unless another 2 months of listening to that clunk doesn't bother you.Awesome. Thanks!
What's your opinion on this...I have 2k more miles before my 30k free maintenance. That should be about 2 months out. Went to Vegas this weekend and there was plenty of knocking every time the accelerates, turns, and goes over bumps. Should I wait it out or should I just go to the dealership now?
Same experience here with two fronts. Same Moog number, but two different labels. One was "euro" the other was not. The Euro version had a closed end the other had an open end. I only needed to replace the driver's side, so I used that one, and waiting on rockauto about exchanging me the "euro" version for the one I Haven't used yet.Replaced the two rear end links today. Ordered Moog brand from RockAuto. Same part numbers but they looked slightly different from each other. Anyway, took under an hour taking the old links out and contorting the new links into place.
Sent from my iPad using Tapatalk
Front Sway Bar LinkWould you mind telling me what part number for the front pieces? I've narrowed the search down to "Tie Rod Ends" but that's all.
Thanks a bunch, Stephane.Front Sway Bar Link
Moog K80478
Rear Sway Bar Link
Moog K80482
Stephane
