buyingconstant7
Back when my 2006 Jetta TDI was new, I specifically remember it delivering me near-instant heat and the idle raised to about 1,000rpm when I first fired it up on a cold day. Assumed it had some sort of heater in the airbox and left it at that, it was great! Fast forward to 15 years later, I noticed it wasn't giving me heat anymore right away, and I'd have to wait until my coolant temp started creeping up. I scanned it for faults and sure enough I have the code set in the aux heater module for heater element defective. I opened it up, and visually couldn't see any issues with the soldering. I went to a local scrap yard and pulled two from other 2006 Jetta TDI's. Tried one, code stayed and nothing happened. Tried the other, code went away instantly without me clearing it. Did an output test, nothing happened, then it set the same code yet again. I checked my original one, and I wiggled each resistor with a screw driver and one came off easily, the other ones wouldn't budge. So I assume I've found my problem. Just wondering if anyone could give me advice, I hear the car locks out the module once the aux heater has been detected as a failure, is this true? Can I just reolder and slap it in and everything will talk to each other and it's good again? And should I add solder to the circuit board where the resistor came off? Or should I just hold a hot solder gun to the resistor, allow the old solder to melt and let it cool again?
