timirving
Do I need to get rid of the 5 brake light mod if I get a euro switch? The switch has a rear fog light setting; will the brake light mod screw this up?
The Euro switch won't affect the 5LBM but if you want to use rear fogs it will.Do I need to get rid of the 5 brake light mod if I get a euro switch? The switch has a rear fog light setting; will the brake light mod screw this up?
This is something that you can do on A4 platforms. The tail light housings both have empty spots that in other non-US areas would be rear fogs. Install a bulb and a jumper wire and you now have 5 brake lights. AFAIK the A5 tails don't have this empty spot.sfpegasus said:What is the 5 brake light mod? Link?
Thanks for the info.This is something that you can do on A4 platforms. The tail light housings both have empty spots that in other non-US areas would be rear fogs. Install a bulb and a jumper wire and you now have 5 brake lights. AFAIK the A5 tails don't have this empty spot.
