I am in the process of rebuilding the engine in my 03 jetta tdi. My block is back from the machine shop where they had to rebore due to a scratch in cylinder 2 and deck to true it up. I have assembled the block with asv pistons (+.5mm) to check the piston protrusion (multiple times)and these are the measurements I got:
Cylinder 1 =
.0345" .0355"
.0345" .035"
.035" .0355"
Cylinder 2 =
.0355" .036"
.036" .0365"
.036" .036"
Cylinder 3 =
.034" .036"
.034" .0355"
.034" .036"
Cylinder 4 =
.0365" .035"
.0355" .0345"
.0355" .0355"
All measurements were taken on the centerline of the wrist pins using a Starrett dial indicator, magnetic deck bridge and machined 123 blocks.
My question is do I really need to take it back to the machine shop or leave it be? If I take it back then there is a small chance they could overshoot. If it does need to go back how much should be taken off? I know the one hole head gasket spec (which I was shooting for) is .0358" - .0394"
I just don't want any issues like hard starting...etc.
Cylinder 1 =
.0345" .0355"
.0345" .035"
.035" .0355"
Cylinder 2 =
.0355" .036"
.036" .0365"
.036" .036"
Cylinder 3 =
.034" .036"
.034" .0355"
.034" .036"
Cylinder 4 =
.0365" .035"
.0355" .0345"
.0355" .0355"
