reildawg
Decided it was time to fix the thunk sound when I brake, but ended up in a bad situation. I ordered new mounts and TTY bolts, but the threads of the bracket bolted to the engine have been damaged by a previous owner/mechanic. The 2 bolts connecting the mount to the bracket were,
A) an oversized TTY bolt
B) a high grade steel bolt with locking washer
A helicoil came out with the TTY bolt, the steel bolt had just been torqued in by force it seems (coarse threads in fine thread hole). I don't need the car immediately, but I would like this to be fixed. Should I find oversized TTY bolts that fits? Get a whole new bracket with good threads and bolt it on? Or just just 2 high grade steel bolts? Any help would be good, if anyone has a spare engine bracket that would be even better. Cheers.
