rrrcryst
Have been looking for where this has been relocated to. My 96 Passat TDI has it just to the right of the steering wheel. Where is it on the 2010 Jetta?
I really hate ramps. I had some I used once and they slid on the concrete and got spit out the front.
And this has what to do with the OP's question???
Thanks I will check it out in the daylight. 27000miles and getting a service needed message so need to check it out with my Harbor Freight tool.Look above the pedals. It is on the left side, on the panel that covers the bottom of the dashboard
That would be correct. Don't know what happened, but my post did not go were I intended.Methinks Ol' Rattler accidentally posted a comment for the "I suck at driving a stick thread" in this thread.![]()
Thanks found it.Also got a $7E8 code which is apparently a too rich oxygen sensor. Is that a warranty repair. I am over 3 years now but the EGR system has ,at least I think, a longer warranty. Any reason for the cooling fan to run a bit excessively sporadically when the engine is shut down. Doesn't seem to do it all the time.Thanks I will check it out in the daylight. 27000miles and getting a service needed message so need to check it out with my Harbor Freight tool.
The occasional, loudly running fan seems to occur when the engines been shut off during a DPF regen cycle. Not to fear, just cooling the filter down from its 9k degree atmospheric re-entry.Thanks found it.Also got a $7E8 code which is apparently a too rich oxygen sensor. Is that a warranty repair. I am over 3 years now but the EGR system has ,at least I think, a longer warranty. Any reason for the cooling fan to run a bit excessively sporadically when the engine is shut down. Doesn't seem to do it all the time.![]()
