oddfatherskidz
I've got a 1998 VW Jetta TDI 5 speed it's a mk3 idk if it was a split year or something buts it's a mk3, I went to start the car yesterday and it cranked for a split second then I lost everything, I've gone through my grounds they seem to be good cleaned up and tightened, my battery is good, relay 109 was replaced and all the fuses seem to be good, I've got voltage going to the fuse panel but I've got no electrical power at my instrument cluster doesn't show mileage or the clock no door ring no done light not radio not anything any ideas? My next replacement is the ignition switch kind of a shot in the dark but I work tonight and ran out of time so I'm borrowing a friend's car I've got it down to the bearing thing behind the steering wheel once I can figure out how to get that off I'll replace the ignition switch as well. Any input will be very much appreciated.
