Rig
My 2006 Jetta TDI has had (since about 40K miles) little intermittent grunting noises you can hear at idle, especially when you are under the car. The sound is coming from the final drive area between the transmission and the engine. I have had the DSG and the final drive serviced, with no dirt or particles appearing in the old fluids.
The sound is like what you get when a small sealed bearing is going bad. The noises haven't gotten much louder in the last 80K miles. The DSG has always been slow to respond; like when you are trying to climb a ramp in the shop, you can't ease up the ramp because you need to give it some accelerator to kick it in gear. Also, when it is cold (below freezing), the DSG is sluggish and puts a drag on the engine even in neutral or park.
My mechanics and I have speculated it could be a torque converter issue or maybe even the enclosed transmission pump. But without taking the engine out and digging, there is no way I can tell.
Any guesses?
Any guesses?
