hangman
that’s correct. I got no voltage when testing those two connectors. I’m going to get the 10 amp in-line fuse, and a couple of small spade terminalsYes, that's the idea.
So, just to confirm, I see that you have a picture of the T10a connector in the floor with the seat harness connector removed:
Tester set to DC Volts, red probe on terminal 9 (left spade in bottom row) and black probe on terminal 5 (right-most spade on top row), measurement is 12V or 0V.
If 0V here is confirmed, you should be able to use a couple of (smaller) spade terminals to supply 12V through the female side of T10a to the seat back motor switch. --g
