Boesdm
I have a 2015 Jetta TDI S, and I'm having issues with rolling down the window. I swapped out the switch, but no go. I took out the plug to check for wire breaks, but couldn't find any. When I plugged it in, the window rolled down and up for a while, but wouldn't roll any others down. Then it would stop working. I can consistently replicate these symptoms. Also, everything else works as it should on the door. Any ideas?
