lemoncurd
Was just curious if there would be a market or interest for a electronic N75 adapter/translator/converter
The N75 valve is pretty simple from a electronics perspective, just a energized 12v coil which gets pulled to ground by a wire from the ECU.
It is pulled in accordance with a sine wave, though this wont matter much as in the digital adapter we can do whatever we want with whatever information. So this can change
I have some experience in designing embedded electronics aswell as coding them.
My idea is to have a small embedded device plug into the N75 valve connector, then connect to a digital VNT actuator seen on other vehicles aswell as the digital sensor connector which would normally plug into the vacuum actuator. The electronic actuator will be controlled by this embedded device through the ECU's N75 commands. In theory and done correctly this would allow for a plug and play swap from a vacuum actuator to a digital one. You could then do other fun stuff like add trim values to the digital actuator, add canbus so we can loop in vehicle parameters like speed / EGT / boost / etc.
Perhaps there is a way to simply add an electronic actuator without all this custom nonsense, i am unsure.
