TDI Believer
Responsible For Global Warming
Just thought I'd mention that the crankcase ventillation systems employed on diesels are not PCV (Positive Crankcase Ventillation) systems. They are Closed Crankcase Ventillation (CCV) systems.
A PCV system utilizes strong engine vacuum to draw gases and vapors out of the crankcase via a one-way check valve known as the PCV valve. These systems also generally include a breather cap/filter or tube to let air into the crankcase so that the crankcase is neither pressurized or depressurized.
Diesels do not produce sufficient vacuum for a PCV system. They use only a crankcase breather which is vented to the filtered side of the intake ducting. The engine can "breathe" both in and out via the breather cap. The round black thing on the TDI valve cover is a breather cap.
On both PCV and CCV systems, the breather cap usually employs a baffle or mesh for the purpose of preventing oil from splashing into the vent tube and entering the intake.
All this talk of PCV valves on the TDI was starting to get to me.
Rich
Rich in Northern VA
2000 Jetta GLS TDI Manual
Canyon Red/Beige
w/Lux/Cold/6CD/Mikro-Audio/BORA Badge
VA Tag "BORA TDI"
[This message has been edited by TDI Believer (edited May 31, 2000).]
Rich
Rich in Northern VA
Canyon Red/Beige
VA Tag "BORA TDI"
