I've been on the mailing list for almost 2 years now and have finally gotten an update regarding Diesel Powers new tuning box for the CR 2.0 engines
http://www.parleysdieselperformance...module-for-2009-2011-vw-and-audi-2-dot-0l-tdi
I found the FAQ very interesting. Especially the part about using without limitation with the DPF installed. I know that Malone recommends installing an EGR block-off plate as well as using a DPF deleted exhaust. I've emailed them for some clarification on the subject as well as if a stage 1 or 2 intake would also be recommended for use with their new product.
Would like you all to way in here and tell me what you think.
And here is the link to ParleysHello,
We are sending you this email to let you know that the VW TDI Diesel Power Active Injector Control Module for your 2011 TDI is finally ready for release. After almost two years of research, testing, and development, we're pleased to announce that Diesel Power has released a unique power module for the 150 Volt Injector 2009, 2010 and 2011 2.0L TDI engine. The engineering on this module is considerable, and we know the results you get when you hook this to your TDI are going to impress you.
Unlike previous 1 and 2 channel power modules for the 2009-2010 2.0L TDI's which controlled input to the ECU via the rail pressure and boost sensors, this new module installs by hooking 4 separate harnesses into each of the individual injectors. This module actively controls individual injector timing, rather than trying to send a signal to the ECU. The result is awesome. Lots of power, lots of speed, true active injection control.
These modules are in stock now and ship the same business day you place your order. Installation time is about 20 minutes and when removed before service or repairs, the unit won't void your VW warranty. Here's a link to the modules:
As a way to thank you for being on our interest list (and some of you have been patiently waiting for almost two years - we haven't forgotten about you!), when you go to check out use our special 2011 TDI owner coupon code "SAVE11" to get an 11% discount off your purchase of this Diesel Power module.
If you don't have a 2011 TDI and received this email in error, we apologize. Work on the module for the 2012-2013 TDI's continues, and we hope to announce release of that product in the near future. Thank you again for your time and we appreciate the opportunity to serve you.
