mountain lion
Driving home last night in my 04 PD, cruise control at 70mph. Just clicked over 222,000 miles and all the sudden I was decelerating and there no engine power. Lights, etc all remain on but slowing down and losing road noise I realize the engine is off. Able to get off an exit safely. Pull they keys out and back in and try to restart, the engine turns over but does not fire.
I let it sit for a minute, turn the key back on, don't see the glow plug light and don't hear the fuel pump prime (it's almost 2 years old, w/ 100k miles). Try a few more times, nothing.
Do a quick search and symptoms point to maybe relay 109. Had the car towed home and here we are today. I woke up and immediately found a replacement 109 relay from a local Euro auto shop. Once it warmed up I went outside and noticed to mess with the car again - the glow plug light is working now with the original realy. Forgot the light won't turn on when the engine is stilll hot- duh. Replaced relay 109 anyways with the new one.
Still nothing, cranking but no start. Glow plug light goes on , but I do not hear the fuel pump prime. When I turn the key off I don't hear the normal 5 clicks of the ASV do anything either.
Pulled out the VCDS and did a scan - throwing this code: 01314
Friday,21,November,2014,14:36:27:43551
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
Mileage: 357280km-222003mi Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 R HW: 028 101 114 6
Component: RC s05g EDC G000SG 0282
Revision: 12345678 Serial number:
Coding: 0150031
Shop #: WSC 66565 257 00032
VCID: 2D5F09CBB7BB2149F4D-515A
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 336B1FB3519F77B9A29-515A
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0003
Coding: 12340
Shop #: WSC 00066
VCID: 2753FBE3C5470B190E1-5120
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 906 Q
Component: KOMBI+WEGFAHRSP VDO V55
Coding: 13232
Shop #: WSC 00222
VCID: 3B7B379329CFBFF97A9-5120
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: 70E1D0BF30090CA19FB-5120
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00257
Shop #: WSC 00066
VCID: 37732BA315E79B999E1-4B18
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0202
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 F
Component: Radio ZSW 0016
Coding: 00401
Shop #: WSC 00066
VCID: 234BEFF3B17FE739529-5120
End-------------------------(Elapsed Time: 04:40)--------------------------
Ok, ECU connection maybe? I pulled the cover, disconnected the ECU wire harness - no signs of corrosion or anything else wrong. Plugged it back in, cleared the codes and ran another scan. No faults found now, but still same issue with not starting.
Where should I be looking next? Maybe test the voltage to the fuel pump and make sure it's still working? The other thing that concerns me is I don't hear the 5 clicks from the asv when I pull the key.
At a loss welcoming advice
75 76
Coding: 0150031
Coding: 0004097
Coding: 12340
Shop #: WSC 00066
Coding: 13232
Shop #: WSC 00222
1 Fault Found:
Coding: 00006
Shop #: WSC 00066
1 Fault Found:
Coding: 00257
Shop #: WSC 00066
Coding: 00401
Shop #: WSC 00066
