alicat2441
Not sure if I'm in the right area being a newbie, but here is goes. I have a 2010 VW jetta TDI with 72K milage. My A/C started going out intermittently over 3 days, but the last 2 days has worked fine-at stop, city driving, and highway. Just took it to the dealer here in Las Vegas and they want $1700 to fix. Service person explanation sounded strange. To paraphrase he said that the pressure in the AC compressor is low and when that happens "particles" clog up the line and cool air doesn't flow. Now I'm a girl and that doesn't sound right, even to me. So I refused the fix and checked out. On the paper given at check out it says:
"Inspected A/C Blows 48 degrees at idle then at 2,000 RPM blows 75 degrees, checked charge, 525 Grams, Checked pressures, 200 PSI Idle, 2,000 RPM high side drops to 125 PSI, Compressor not producing pressure off idle."
I did a quick search on Google and this seems to be a common problem with the 2010 VW Jetta TDI and some forum boards are saying that it is a high pressure valve or RCV (?) fix.
I know the compressor works, just not all the time so that makes me think it is a pressure valve. Seems to me the dealer just wants to replace the whole thing and make money instead of pinpointing the problem and saving the consumer money.
Oh, almost forgot to mention that the fans run fine from low to high. And when the AC didn't work right for 3 days the way I got AC was shutting off the fan for about 10 sec then turning back on and cool/cold air would be produced.
Any ideas? or thoughts?
