gdunn
- Joined
- May 12, 2003
- Location
- Hillsdale, Ontario
- TDI
- Golf, 2k, Green, Auto: Jetta 2003, Black, Manual
I'm in the midst of changing my driver's side CV Joint and I think I might have found a problem. In the HowTo, they talk about:
1) Clip 1 - in the groove at the end of the axle.
2) Dished washer - a concave metal washer that butts up against the thrust washer.
3) Thrust washer - another washer (tough plastic)
4) Clip 2 - It's still 'in the groove' in the HowTo so I'm not sure what it looks like. I believe this one has to go on the axle first when re-assembling (then the dished washer, the thrust washer and clip 1).
If you look about 3/4 of the way down this page:
http://www.myturbodiesel.com/1000q/b5/CV-boot-broken-replacement.htm
You'll see a picture that (I think) shows that Clip 2 (he calls it 'inside clip'--it's not a full washer, but rather a large C shaped washer). That clip is nowhere to be found on my axle. A replacement didn't come in my new kit (although they did give me 2 of Clip #1).
I know this joint was changed in the past so I'm wondering if the previous mechanic forgot about it. Or was it supposed to come in my new kit?
Either way, I'm assuming it's important enough that I should get that part. The joint has been clicking on me ever since I've had the car and recently it's been getting worse. The joint & boot that came off looked good, so perhaps this missing clip has been the source of the clicking all along.
Any assistance is appreciated!
