logique
I just completed an engine swap in a 96 passat VR6 from a 96 Passat TDI. Everything is working as expected, however I have no cruise control. Prior to swapping the engine, the TDI's cruise control worked perfectly.
Besides the engine, I swapped the ECU, wiring harness and pedal cluster. The brake and clutch pedal switches appear to function properly. In VCDS, measuring block 006, I get what you see in the screen shot when I push on the clutch and brake pedals. When I let go, I get all zeros which I think is normal. When I turn on the CC, I get nothing, no cruise present and all zeros. I also tried this while driving the car and the speed field was accurate. I tried the two switches from both cars and they both give the same result. Like I said, this switch was working fine in the TDI.
I also deactivated and reactivated the CC in the ECU using the "Login - 11" and codes 16167 and 11463. I was able to verify this by looking at the component code in this screen shot. The letter G before "70SG" disappeared upon deactivation and reappeared when reactivated.
Any ideas what I may have overlooked and what I could test?
