Cruise control Issues
Reidjc0826
Ohio
1999 Alh
Hey guys I was on her a couple days ago speaking about fuel mileage and I now have vcds and looked at my cruise control blocks and it says that my clutch is stuck on the 1 and when I press it, it does not make a difference. I also tested the clutch switch with a multimeter and it shows different ohms when you press it in and out. I already have a new switch on the way but if that doesn't fix it where would you guys be looking next. I'm not sure if maybe a fuse is blown or if I have a wiring issue. I also am not sure but I don't have a light that comes on when I turn on cruise on the stalk. Also everything else on vcds seems to work correctly when pressed. Just to clarify I have a 1999 early year (duh) Jetta TDI.
