jtree
I recently installed a CR190 / gtd1449vz turbo on my 2016 TDI wagon.
How can I adjust the charge pressure actuator? I have a vcds hooked up and it shows the voltage at 8 instead of the desired 3.6. The actuator has no threads or obvious way to adjust it.
The car isn't making much boost until 3000 rpm and only is making a max of 18 psi of boost at 4000 rpm. I have a Kerma stage 1+ tune on the car and also tried it with the stock tune, which had the same problem. I dynoed the car and it is making less power befor 3500 rpms and a bit more from 3500-4000 rpm.
