TDIJetta99 said:
you just have to let it sit there and run.. it will take quite a while..
The ECU doesn't have any control over the fans on an ALH car... It's done solely by the fan control module and the thermoswitch in the radiator.. The fan control module ONLY turns the fans on with the A/C and has nothing to do with engine temperature, and the thermoswitch turns them on via engine temp.. Low or High depending on temp.. The fans will work via engine temperature even with the fan control module unplugged..
edit.. just seen you have a 2005.. not too sure if the ECU has fan control or not.. I'll look up some wiring diagrams tomorrow
The ECU on ALH cars after May 99 does have some fan control, and the circuitry is the same on the PDs through 2005.5. The BRM is where the shift occurs.
Slow speed fans can be turned on by the radiator thermoswitch - radiator temperature half way down the radiator - no matter if the key is on or off, FCM plugged in or not.
Slow speed fans can also be turned on through the FCM slow speed fan relay when requested by the AC system, or when requested by the ECU.
Fast speed fans are always turned on through the FCM. The request for fast speed fans can come from AC pressure or from the radiator thermoswitch through the FCM, (80% confidence -or from the ECU), but the only relay that turns them on is in the FCM.
I have seen some ALH Engine Control module output tests that do test the slow speed fans, and some that do not. I am not sure why they are different. I never noticed the ALH ECU output fan test until the last year or so - perhaps it is an updated VCDS?
The PD ECU Output tests always checks the ECU's ability to start the slow speed fans. On the BRM it tests the variable speed control.
At least this is my interpretation of the Bentley drawing.
