neimis
- Joined
- Dec 12, 2000
- Location
- Victoria, B.C., Canada
- TDI
- '92 Passat TD, '01 Golf GL TDI, '15 Golf Trendline TDI
Topic says it all. I've been trying to figure this out for years, I'm finally convinced it's engine oil. Car is a '92 Passat with the 1.9 litre IDI. I think it accumulates in the reservoir because that is the highest point in the cooling system.
What are all possible ways oil could find it's way into the coolant? Oil cooler? (has been pressure tested, shows OK) Head gasket? (compression is good, no steam ever in exhaust, no need to top off coolant).
I need to fix this problem once and for all before I change out the thermostat, install a new thermoswitch and flush the coolant system, etc.
Any help and ideas appreciated.
