Coolant blown out from expansion bottle
Janchee
UK
VW Golf MK7 1.6 TDI 105 Manual 2014
1 year later … and my 1.6 CLHA mk7 golf manual blocked again (even with new matrix) and I think I know why.
I only drained the front main radiator and intercooler radiator last year when changing the matrix. I was also happily squeezing all the hoses afterward to get rid of air … which might of accelerated stuck sludge straight into the new matrix! You live and learn.
Anyway, spent the Saturday morning fixing it. This time also removed pipe from rear electric pump when draining coolant and loads more coolant came out. Bought the heater matrix (linked somewhere on this forum) which has bigger ‘holes’ etc. about £110 incl delivery. Idea of bigger holes sounded good as I don’t think I’ll ever flush it properly on my drive or pay VW thousands to do it!
Well, in the end I had to properly flush and refit the oem part I installed a year ago! This other new matrix I had bought was a pain! It was hard to slide into the matrix hole and then I couldn’t for the life of me get the pipes on past the o-rings! Seems like the oem one has a chamfer to slowly squeeze the o ring into it and this one is just 90deg edge. I gave up in the end as it would be my luck that the o ring would be damaged on reassembly!
Tried doing the bleeding via OBDeleven and just couldn’t get any of it to work. VCDS definitely seems like a good option for this.
I did vacuum fill and the golf only took 4.7 l of G12Evo. I see sites quoting 8l capacity so I must of missed some coolant somewhere!
Heating now back in the drivers side ready for the colder days in UK.
Some top tips
- Get a pair of long wire hose clamp pliers! It’s tight when you need to remove pipes from pumps (as they’re not quick release clips)
- If possible, get vcds or find a friend that does have it!
- Replace coolant reservoir. I did mine last year as it had so much bad stuff in it !
- use OEM or similar part. If you’re doing it on your driveway, last thing you want is to be effing and jeffing with a matrix that doesn’t fit or is awkward!
- I bought a cheap vacuum kit on eBay for £30 last year and it works really well.
Janchee
UK
Hi there,
I've just been pointed to this thread. I've got a 2 litre diesel Skoda Octavia. I've got coolant levels dropping slowly (and looking a little murky - but I don't believe it's a head gasket issue) and also have no hot air (going to confirm later if it's just some fans blowing cold). Garage is unsure what it could be and is suggesting replacing parts methodically (fortunately they don't want to waste my money like a main dealer).
There's a lot of info in here, much of which I don't understand. I was wondering if anyone could advise on any sort of specific checks that can be done to try and confirm if my issue is the heater matrix?
I've read about an issue being regeneration related. Unfortunately I don't actually know how I can tell if my car is doing a regen or not: ( Also I've seen people mention a coolant overflow (is that an overflow valve, or when removing the cap when the engines hot)? Hoping someone could point this car n00bie in the right direction!
Get it sorted? Will be matrix. Look for pink / white spots on engine mount. DPF regen causes very hot coolant to be injected into matrix and if it’s blocked, it’ll go via the air bleed pipe at high pressure to the reservoir and will be released via the cap. The coolant reservoir cap has an automatic bleed off pressure hence why your levels will drop and you may see pink spots on the engine mount! Another tell tale sign of matrix is a basic coolant leak test will come back ok because there technically isn’t one :)
ipwright83
UK
Skoda Octavia
Thanks for the advice on here. I've just got my Octavia back today with hopefully the coolant leak fixed.
My heater matrix was totally gummed up. The silica bag removed from the replacement. It took a while to get sorted as I also had an accuator fault on a heating vent meaning half the car wouldn't have heated anyway.
scaper28
UK Gloucester
Golf 2.0 GT TDI 2013
After reading this post I think I have the same issue ,
I have just had a quick look to see which version of the heater matrix I have the A or B however I have not had chance to remove the glove box yet. can anyone tell by my pictures by any chance ?
also what is the best way to do a flush of the system ,
" Picture share link below "
2 Items
FJBGTD
Southampton
Golf GTD
2 Items
It is a Valeo, you can see it printed on the plastic matrix cover in your picture.
scaper28
UK Gloucester
Thank you very much is that the A or the B version ?
When I went to VW parts they said its either the 5Q0 819 031 A or the 5Q0 819 031 B
Due to them wanting £300 odd for the part I want to make sure I get the correct one.
FJBGTD
Southampton
Golf GTD
Valeo is 5Q0819031B, £300 is a ridiculous price, get a quality aftermarket unit like Nissens or NRF for less than £100.
Scotland
20 ltr
I have the same issue 20 tdi loosing water out the coolant bottle…spent fortunes on it replaced everything imaginable, mechanic has told me it’s now finally sorted I’ve to collect car tonight after he road testers it today. Still not sure what was the cause I’ll find out later
scaper28
UK Gloucester
I thought it was expensive , you don't have any links to where I can get a good aftermarket one by any chance as I want to make sure I get the correct one .
Thanks for your help I appreciate it
scaper28
UK Gloucester
Try Parts in Motion https://www.partsinmotion.co.uk/ put 5Q0819031B in the search box.
They only sell quality parts.
Thank you , I will have a look on there now. WOW so so much cheaper , I am torn between either the NRF one at £72 or the FEBI one at £91 ?
One last thing , I was going to dump all the water out of the car by removing the radiator pipe. is there a better way to flush the system though or do I not need to ?
FJBGTD
Southampton
Golf GTD
Try and get as much water out as possible and flush through with clean water. To fill the system properly, you will need a scan tool to activate the bleed process and a vacuum fill device. You can do it manually but you will likely hear the sound of water running behind the dash for a while until all the air works its way out.
scaper28
UK Gloucester
Right so if I am right in thinking , remove radiator pipe. unscrew expansion tank cap once all water out , run a hose into the expansion tap and leave running until nice and clear. then change the heater matrix, fill with G12EVO and run VCDS bleed cycle
I am so glad I posted on here thank you so much for your help.
FJBGTD
Southampton
Golf GTD
That is pretty much all you can do without a VW flushing machine. You could put the rad hose back on and remover other cooling pipes, such as the charge cooler and heater pipes on the bulk head, and run the hose again.
scaper28
UK Gloucester
Thanks I will try those for a good flush of the system.
Just trying to work out which part to get the £71 NRF or the £91 FEBI one ::ROFLMAO:
Janchee
UK
Try and disconnect both pumps at front and back of engine block. Note that some aftermarket parts don’t slide in like VW ones so make sure you’re ready to have patience.
I replaced my coolant reservoir tank whilst I was at it as that was full of gunk.
If you flush with hose, make sure you get all of that out as it will react with internal components.
scaper28
UK Gloucester
Ah that is a concern as I dont want to be stuck trying to get it in and the pipes to seal/fit correctly. Which part one did you use I am still debating over the NRF or Febi or now even another make lol
I have purchased a new reservoir tank and cap also and 10Litres of G12Evo .
is there a better fluid to flush with , distilled water or something ?
Janchee
UK
Make sure you have some long reach flexible hose pliers. They are a god send :)
I tried the heater matrix which claims they use bigger holes (around £100). I couldn’t for the life of me get the part into the ducting. I sent it back and in fairness to the company, they provided a full refund.
I then managed to find a brand new genuine Heater matrix on eBay which had never been used for £70.
Distilled water would be better as you’re then not concerned about it. It’s not a deal breaker though.
scaper28
UK Gloucester
Wow £70 for a new genuine one that was a lucky find...
Did you use distilled water on yours then and the long reach flexible hose pliers for the engine wall pipes ?
Jaume
Valencia, Spain
Seat León FR 184
Hi,
I found this forum some weeks ago because I was facing the same issue with my Leon FR 184 (diesel). To give some context: in march 2023 while driving in the night I hit a bump quite strongly and after some km of driving I noticed bubbling noise through the dashboard. In the morning, the low coolant alarm went off when I started the car. I had it checked where I bought it (second hand, imported from Germany in august 2022 and I had driven it about 10k km already with NO problems at all), but they only changed the tap. The problem persisted and they changed the tank. But it persisted. After a few visits to the garage, no leaks were detected and discarded also head gasket problems. They also bypassed the EGR cooler.
When I found this thread, I had my heater matrix checked a couple weeks ago and one of the two parts was irretrievably clogged, so it was changed and the other one cleaned by another garage (lost confidence in the seller because other issues). Also had the system flushed. All the pumps have been checked and no malfunction signs were found by the garage. The problem has appeared again: coolant is lost by the expansion tank (through the back) after some miles. The fan had been functioning the day before as it was in DPF regen mode, so I assume the problem remains the same. I have bought an OBD reader and will try to monitor these episodes in case some alarm is trigged, but I’m losing hope.
Any ideas on where to look or any advice? Sorry for the long post.
heathy
Hull
Golf GTD Mk7
I think I may have the same issues stated here, around 5 weeks or so ago I got the coolant warning light, expansion tank was completely empty. Topped it up and had a mechanic look at it while I had an interim service he said small crack in expansion tank, easy fix £27 tank and 10 mins fitting. A week later leak again, this time I took it straight to the local VW specialist, they couldn't find any external leak and said to monitor it and see how often it loses coolant, they thought it might be leaving via the exhaust. I also did a sniff test for combustion gases prior to this and came back negative. I then had it another week and lost coolant after around 300 miles, was pretty pissed off by this point as I couldn't see how no one could find it.
I then took it back to the first garage who checked it as they also changed the water pump last November and I was certain it was that or the thermostat housing, they said they couldn't find any evidence of a leak from either of those and suggested the next step would be the EGR cooler for circa £800, they advised me to get rid of the car, but by this point I had done a lot or research and found this forum and I'm now convinced it must be linked to the Heater matrix like others before me. I also couldn't see the silica bag in my old tank so wonder if that is connected.
I'm now planning on changing the heater matrix myself, can get one for around £70 and doesn't look too hard to do. I'm more concerned with the coolant, this was changed when my water pump was done, would like a full flush but just don't have the money or equipment to do that, I'm thinking of just throwing the new matrix on maybe I will drain and fill myself or get it done afterwards at a garage for like £40, I don't plan on keeping this car much longer now, I just want to stop the coolant leak which seems to occur at intervals rather than constant which may be linked to the DPF regen, not really noticed on that aspect. If it was a constant leak then surely that would point more to something like ego cooler or head gasket, I've not had any other symptoms, car drives perfectly, no smoke, no power loss, no white froth in oil or coolant tank, coolant looks brownish and smells but cars stays in the middle oil temp on motorway is always around 105, I do only have heat on passenger side but been like that for a while, so wondering if there is only a partial blockage that will still pass a pressure test but under certain conditions or DPF regen it overpressure the system and forces it out the tank as described above.
For replacing the matrix is it as simple as just taking the old one out sliding new one in and then maybe try and work some air out squeezing pipes, have the engine running and heating on to draw coolant into the new matrix and then top off the tank as needed with fresh coolant? My plan is to just get a new matrix on maybe give it a week or two and see how it goes then maybe have a coolant change done as a full flush seems out of the question, given how complex it seems and I can imagine expensive. Any advice would be appreciated. I have a Nissens denso unit already on there as It was losing coolant after I bought it and I'm sure they changed the heater matrix then too, clearly these cars have a issue with this.
Smidemann
Denmark
2.0 tdi CUNA
Sorry for my English 😅...
Happy to see im not the only one struggling with this heatermatrix problem 😬...
Mine 2.0 tdi 184 Leon 2015 did the same, vomiting out thru expansion tank 😒...
I did however get it fixed, dealer ship has been replacing complete egr system, intake manifold, turbo, oil cooler and a **** loads of different parts on guarantee, they still haven't got it fixed 😅...
So i ended up changing the matrix and expansion tank 👌, as far as good, but it is still overheating when cleaning the DPF according to VCDS, display temperature aint worth ****, says 90° all the time, but the actual temperature was above 100°, so i contacted a well known vag tuner, he did pull out 217 hp and 453 nm on dyno (see link below), updated software on dsg and shut down the egr system for good... It pulls like freight train now and drives like a charm, tried to floor it with the caravan on, 1800 kg, it did not really care about it, it just pull off to 100 km/h without any trouble of overheating or anything like that 🤌...
heathy
Hull
Golf GTD Mk7
Yeah seems to be a common VAG issue. The day I posted this I drove home and had a DPF regen and could smell coolant, got home and went back out after the engine cooled and no coolant in the expansion tank, so that confirmed it for me, this definitely happens during a DPF regen. I do have a heater matrix due to be delivered so I will hopefully be fitting that this weekend and hope that fixes it, I already have a new expansion tank on.
Nice to hear you sorted your problem and got some good results on the dyno. I will post another update once I fit the new matrix and see if it solves the problem. I'm due for another coolant leak today as it seems to happen every 300 miles/500Km. I'm glad I have found this thread and others like it as now I have managed to pinpoint when the problem happens and a possible fix.
liamtatham
New zealand
1.6 blue motion
Hi all, new member here from New Zealand. Just bought a 1.6 tdi golf 2013 (130kms) as a work run about… just want to say thanks for all the info in this thread. The golf I bought had no heat at all and the coolant would periodically spill out with residue found on the reservoir / engine bay…,found this thread and changed the heater core which was grotty/ partially blocked… seems that coolant no longer escapes and heat works, have put around 1800kms on the car since the fix.
just a couple of follow up comments, I flushed the coolant system multiple times and found evidence of the desiccant in the coolant, although the bag was not broken there were gritty fines coming from the bag when you moved it in your hand and in the bottom of the container used to drain the coolant into.
Couple of questions for people have been through this, I topped up the coolant just above the full line and it appears I’m maybe losing some very slowly, it’s now just below the full line, should I be worried ? Engine doesn’t get hot on the gauge and no evidence of leaks on the heater core or anywhere obvious. Not overly sure but exhaust does smell sweet to me…Do I next consider a Egr or oil cooler leak? What should I watch out for? thanks a lot everyone!
heathy
Hull
Golf GTD Mk7
I changed my heater matrix on 4th May, it was a denso matrix, easy to get to, had to take the glovebox out, sat nav and some trim on centre console, very easy to get to really and easy to get the old matrix off, but trying to get the top pipe back on was a terrible job, I spent about 2 hours wiggling trying to get the pipes to meet up, eventually I wiggled them close enough and used a screwdriver to push the o-ring in as they kept popping out, used a lot of grease too, still hard to do, once I got them close enough I pinched them together with pliers.
Seemed to fix the heater issue for a few days, although seems cooler on one side now, not as bad as before but still cooler. I'm still losing coolant, not as much as before as it would completely empty now it drops while still keeping some coolant, so I feel like it is connected. I have had about 2 DPF's since and lost a bit of coolant on both. I haven't flushed my coolant because I just can't do it properly myself and reluctant to pay hundreds for it if it won't even make a difference. I might pay a garage to do a coolant change see if they can get rid of some of the crap in the system, hopefully my new matrix isn't blocked a bit too, the last one I took out was very poor.
So my situation has improved slightly but not fixed, im certain it is the matrix as no other symptoms and the issue has improved but still happening a bit under the same conditions. Frankly I'm sick of this car now, I think im just going to end up getting rid of it before anything worse potentially happens down the road. I love my golf but its put me off buying another VAG car seen as it's just magically losing coolant and no one not even VW specialists or VW themselves according to some here, can find the actual fault and fix it.
Audi Fan
EU
Audi A3 8V sportback TDi 2.0 Quattro
Hello Guyyyz
Adding myself to this disaster with coolant leak...
I believe to solve this crazy matter we have to remove whole engine out of the car, and strip all rubber hoses and pipes and radiators and pumps, strip DPF , EGR , exhaust manifold with turbo, intake manifold must be removed there is coolant too , disconnect all radiators ...
If the car is above 100K the issues begins... unfortunately that's the design ..
I replaced couple of things but it never solved problem.. But there is chance that if DPF is too clogged and EGR too it creates back pressure and coolant will just find its weakest point and will leak.. I have been using destiled water instead of wasting coolant water because was summer very hot..
In summer u don't need to use coolant if it's expensive and constantly spending money buying bottles.. Just heat up tap water boil it and leave cool down and u have destiled water... It must be destiled as ions will vapour from water and pipes and radiators will not rust ..
But if your coolant keeps leaking / disappearing you can still add even straight tap water as it will go away quickly again .. until u replace everything coolant system related...
shocks
Perth AU
Golf MK6 2.0TDI (103KW CFFB) Comfortline, Golf MK7 2.0TDI Highline (CRBC 110KW), Passat Alltrack Wolfsburg Ed. 2.0TDI (DFHA 140KW)
That's not distilled water, that's just water that's got hot. You might have killed a few germs, but that's about it. If your tap water is mineral rich, then you're probably leaving a nice layer of mineral deposits throughout the cooling system and possibly making things worst.
What parts have you replaced, almost everyone having the problem described here has fixed the problem by just changing the heater matrix in the cabin. I don't think anyone had to overhaul the whole cooling system.
Kel8117
UK
VW Golf MK7 GT TDI
Hello Guyyyz
More than likely heat exchanger 👍🏻
