THE MAN is obviously keeping this stuff down.
Larger diesel engines and turbines have broken 50%.
Here's what I 'learned' up:
"Since Nitrogen and Oxygen make up our atmosphere, they liquify at the same temperature."
Oxygen — Boiling Point: 90.20 K (-182.95 °C, -297.31 °F)
Nitrogen — Boiling Point: 77.36 K (-195.79 °C, -320.42 °F)
I'm sure it has nothing to do with the fact that they're close on the periodic table.
"The most efficient engine built and operating today is only 30% efficient"]rh
Large diesels are over 50%.
"Only 30% of the fuel is burned, the rest goes out the tailpipe is pollution."
I could have sworn that the rest was turned into heat. Unless you're smoking all of your fuel should have been burned.
Then the Hindenburg, how to make a pressure vessel, bridges.... I give up. It'd take me hours to do this,
Best part: This guy was entrusted with our national security on the ICBM, good thing we never had to use them.
Kerosene == Diesel.
http://www.fueleconomy.gov/Feg/byfuel/BifuelCNG2004.shtml
According to him they were getting 2 MPG out the Honda CNG they had.
http://en.wikipedia.org/wiki/Radial_engine
Looks like someone has figured out how to make an even numbered cylinder radial.
They haven't been able to make a diesel engine catalyst
Let these companies that sell a diesel oxidation catalyst.
"The only way to go faster is to burn more fuel, which means you burn less fuel."
And there are 2 ways to make liquid N2 or O2. Compress it OR cool it. You can have liquid N2 at room temperature if you jack the pressures WAY up.
The thing that does sound interesting is the comment about the head. If you could mold a cylinder with a perfectly round top (like a propane container). Get coolant lines run, etc, but you'd eliminate the 'weak spot' of the the head gasket.
