Shenandoah
- Joined
- Jan 9, 2008
- Location
- Shenandoah Valley, VA
- TDI
- 2005 Jetta Wagon; 2005 Beetle; 2004 Jetta; 2002 Golf (three of them); 2002 Jetta Wagon; 2000 Audi TT->TDI; 1999 Beetle
Folks,
This is in my 2000 Audi TT -> TDI conversion. The Comfort Control Unit (located on the driver's side under the small side window) has for the past year or so made "clicking" sounds like a turn signal is on. This doesn't happen that often, maybe once a month. It might "click" for a minute or sometimes longer before it stops. I'm not sure if does this at other times (middle of the night, etc.).
Yesterday I went to start the car, but the battery was very low and wouldn't start the car. I had just driven the car the day before. Battery is a year old. I put the charger on the battery and charged it back up. I came out to the car noticed that the CCU was clicking away, like the turn signal was on. I opened the doors, opened the hatch, and it continued on. I tapped the interior panel a couple times where it's located. Eventually it stopped clicking. I did a "google" search and found that other folks had similar problems and replaced the CCU. There is an alarm relay in the CCU that fails and will run the battery down? I noticed YESTERDAY that when I lock the car, the alarm horn does not "beep" whereas in the past it did. I ran a scan with VCDS but no codes showed up.
I can pick up a used CCU for around $100, but wanted to see if anyone else has had a similar problem with their VW? And if they did have a similar problem, was it the CCU or something else that affected the CCU.
Thanks!
Eric
Thanks!
Eric
