Codes thrown just after repair and warranty expiration car went in for DPF failure drove 100 plus miles and car threw some new codes.
looking for answers.
Mike
Sunday,15,May,2022,16:26:57:20162
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 21.9.0.2 HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: 3VWPL7AJ2CM658097 License Plate: ARG
Mileage: 241780km-150235mi Repair Order: fest
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56
62 72
VIN: 3VWPL7AJ2CM658097 Mileage: 241780km-150235miles
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 40942 003 1048576
VCID: 30391855B627BFAB171-8064
VINID: 0E69E070745A0937461480091C24EB3B7B
4 Faults Found:
001025 - EGR System
P0401 - 001 - Insufficient Flow - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 77
Reset counter: 255
Mileage: 238549 km
Time Indication: 0
Date: 2016.09.03
Time: 09:56:02
Freeze Frame:
RPM: 1702 /min
Speed: 53.0 km/h
Voltage: 13.98 V
Load: 94.9 %
Load: 100.0 %
Mass Air / Rev.: 340.0 mg/str
Mass Air / Rev.: 390.0 mg/str
009231 - Exhaust Gas Recirculation System
P240F - 000 - Response too Slow - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 238560 km
Time Indication: 0
Date: 2016.09.03
Time: 11:33:18
Freeze Frame:
RPM: 1794 /min
Speed: 75.0 km/h
Load: 77.3 %
Mass Air / Rev.: 0.0 mg/str
Mass Air / Rev.: 20.0 mg/str
Mass Air / Rev.: 305.0 mg/str
Mass Air / Rev.: 370.0 mg/str
008194 - Particulate Trap Bank 1
P2002 - 007 - Efficiency Below Threshold - MIL ON
Freeze Frame:
Fault Status: 11100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 238655 km
Time Indication: 0
Date: 2016.09.06
Time: 07:12:58
Freeze Frame:
RPM: 1702 /min
Speed: 86.0 km/h
(no units): 81.6
(no units): 25.5
(no units): 2.75
Pressure: 326 mbar
Pressure: 26 mbar
001025 - EGR System
P0401 - 002 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 240473 km
Time Indication: 0
Date: 2016.09.17
Time: 12:01:54
Freeze Frame:
RPM: 1587 /min
Speed: 66.0 km/h
Voltage: 14.44 V
Load: 72.5 %
Load: 100.0 %
Mass Air / Rev.: 345.0 mg/str
Mass Air / Rev.: 430.0 mg/str
Readiness: 1 3 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9430
Revision: 05351113 Serial number: 00001110070909
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 1471B4C5227F638B139-8040
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C49270002880B06ED92200042B70000
VCID: 7DA7F1613DF582C3CC7-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434 B
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0155773423
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 343114454EBF838B739-8060
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001016
Coding: 0000001002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 005988954A87EF2BA71-8054
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 3068
Revision: BG021001
Coding: 6F380E1F802F3EC4008800C17000004449000086575D05F064802020A040
VCID: 392F2571695D7EE3A0F-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 12121 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA0S9MH
Coding: 00003133
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FDB4B6977F950D39EB-806A
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00002G1000
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME04715164ZZZL
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME26225264ZZZN
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME22013C29ZZZC
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME1D0A3B29ZZZV
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME46137128ZZZ8
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME79451C29ZZZQ
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 569 H HW: 5K0 953 569 H
Component: LENKS.MODUL 016 0140
Revision: --X01--- Serial number: 20130529100720
Coding: 100A140000
Shop #: WSC 51780 000 1048576
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 3D2731617DF542C38C7-8068
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
Component: KOMBI H33 0310
Revision: X0033006 Serial number:
Coding: 270F01
ASAM Dataset: EV_KombiUDSMM9RM10 A04305
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 30391855BAA7BFAB171-8064
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 05121101290227
Coding: 352002
VCID: 3D2731617D7542C38C7-8068
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 920 972 C
Component: IMMO H33 0310
Coding: 000007
ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A8DCA3D5CFB057B195-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000191189003
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E05062DA093A95B05D-807A
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661095242
Coding: 020000
VCID: 290FF53199FDCE63D0F-807C
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
Component: RNS315-NAR H33 0265
Serial number: VWZAZ2L8480261
Coding: 04000401040007000000100A
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_RNS315NARV2UDS A01004
ROD: EV_RNS315NARV2UDS.rod
VCID: 2313E719FB5114339A3-8076
Data carrier:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V2 0002
1 Fault Found:
1048642 - Internal Control Module Memory Check Sum Error
B2000 42 [009] - General Memory Failure
[ECU defect data memory failure]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Mileage: 124649 km
Date: 2019.06.06
Time: 01:50:49
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0003711719
Coding: 0004B5
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BE39FF983A16CF3923-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 007 1509
Serial number: 00000006207242
Coding: 000490
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 34311445423F838B739-8060
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 050B0500
VCID: 6FBBDB296799E0534EB-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0003722280
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CE19CE586AF6BCB9B9-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 007 1509
Serial number: 00000006107347
Coding: 000490
End----------(Elapsed Time: 01:38, VBatt start/end: 13.8V/13.7V)-----------
Mike
www.Ross-Tech.com
62 72
Coding: 0050078
4 Faults Found:
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 77
Reset counter: 255
Mileage: 238549 km
Time Indication: 0
Date: 2016.09.03
Time: 09:56:02
Freeze Frame:
RPM: 1702 /min
Speed: 53.0 km/h
Voltage: 13.98 V
Load: 94.9 %
Load: 100.0 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 238560 km
Time Indication: 0
Date: 2016.09.03
Time: 11:33:18
Freeze Frame:
RPM: 1794 /min
Speed: 75.0 km/h
Load: 77.3 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 238655 km
Time Indication: 0
Date: 2016.09.06
Time: 07:12:58
Freeze Frame:
RPM: 1702 /min
Speed: 86.0 km/h
(no units): 81.6
(no units): 25.5
(no units): 2.75
Pressure: 326 mbar
Pressure: 26 mbar
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 240473 km
Time Indication: 0
Date: 2016.09.17
Time: 12:01:54
Freeze Frame:
RPM: 1587 /min
Speed: 66.0 km/h
Voltage: 14.44 V
Load: 72.5 %
Load: 100.0 %
Coding: 0000020
Revision: 00H31001
Coding: 030C0C
Revision: 00001016
Coding: 0000001002
Revision: BG021001
Coding: 009795
Coding: 00003133
Coding: 100A140000
Coding: 820000
Coding: 270F01
Coding: 352002
Coding: 000007
Coding: 020000
Data carrier:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 124649 km
Date: 2019.06.06
Time: 01:50:49
Coding: 0004B5
Slave Driver:
Coding: 000490
Revision: 00H20000
Coding: 050B0500
Coding: 0004B4
Slave Passenger:
Coding: 000490
