roadhard1960
I have used the deluxe timing belt kit which you can order. They come with a new water bump, new idler pulleys, new timing and serpentine belt, and new stretch bolts.
I look at a number of vendors. Some have a new clutch kit that might consist of 6 bolts, a disk, a pressure plate, a flywheel. No throwout bearing, no stretch bolts, no seals, no shifter linkage replacement clips (which appear in the manual to be one time use clips), no oem or better transmission oil.
So for a true pro clutch job, what are the parts that you really should replace? I do not really want to go in to replace the clutch only to have to the throwout bearing sing (one site says you should replace the tube the bearing rides on), not thrilled with the idea of the engine falling out because replacement bolts were not used but vendors will only sell you the bolts if you buy the clutch from them.
I bought a clutch a few years ago when it was slipping but it stopped slipping. Now the car is crabby shifting gears sometimes and I have read that the dual mass sometimes fails with that being the first indicator. Crabby means you push the shifter to the "normal" resistance point only to find that I did not even get it half way in to gear and away it grinds. I hate that the clutch is failing with only 192,000 miles on it.
