jwm9289
2001 NB TDI Five Speed
Cluster problem, odometer & Tripometer both work fine. Warning Lights work Fine. Fuel Gauge Low Light Works.
The Speedometer, Tachometer & fuel gauge are not working.
(stuck on 120mph, 4000 rpm's & Empty.)
Question: No codes in Vag-Com, will bad cluster trigger a code? Could this be a grounding problem? (If so, were is the ground for cluster?)
Any help would be appreciated!
