graeme86
I was sitting in a new BMW 135i Coupe the other day which is fitted with that regenerative braking system. BMW seem to have the confidence that the battery won't go as flat as soon because of this, so you can sit in the car with the ignition off and still have the ventilation fans running.
I was kind of impressed by this feature, seeing as it gets quite hot over here sometimes.
Now, on the VW Climatronic is an input so you can plug in the Standheizung, so it powers up the Climatronic headunit and servo motors when its on.
See this post:
http://forums.tdiclub.com/showpost.php?p=1567537&postcount=52
So I'm thinking, if you add an input, say from the key sensor wire, to power up the unit, and add the switching relay as well (just using a VW Relay #79) to directly power the fans (as described in the linked post), then you could power up the fans when the ignition is off as well in the VW.
I think the key sensor would work well as the source signal because you would normmally be in the car at this time with the key in ignition, so once you pull out the key and get out of the car the fans would stop (saving the battery)
Its only set up to cool you if you are in the car so to speak, not to supply extra ventilation if the car is just parked ( that's for the solar sunroof to do )
Any thoughts/feedback on this idea?
Graeme
See this post:
Graeme
