Hello guys.
Due to a problem where the oil wasn't returning after releasing the brake pedal, the source of the problem was located in the mechanical part of the ABS unit.
So, I got a new (used) ABS module and exchanged the parts so I would use the original eletronic parts, but with that used hydraulics.
Car now brakes okay, but seems like a Christmas tree... ABS error, ESC error, park assist error, start & stop error...
I can clean the errors, but 1s later they surface again (in every module).
The eletronic part (original) reference number starts with 3Q0 but the hydraulics unit starts with 5Q0.
I have a VAGCOM cable with VCDS software. Reading the ABS module I can see the coding is there. Since I changed the mechanical part, is it necessary to perform some coding? If yes where I can read more about it?
A note: when car started for the first time, the steering was hard, after 10s (+/-) it started to soften like normal. Would a calibration solve this?
The car is a VW Passat from 2015 (3G5) and the used ABS module is from a Golf VII.
Errors:
Address 01: Engine (J623-DCXA) Labels:. 0-----7-309-V1.clb
Part No SW: ---------026 GJ HW: 04L 907 309 R
Component: R4 1.6l TDI X21 1991
Revision: B5X21---
Coding: 011900120--------
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM16TDI01104L906026GJ 002002
ROD: EV_ECM16TDI01104L906026GJ.rod
VCID: 78FF5EE2C3D34D8420-802C
1 Fault Found:
17158 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 195122 km
Date: 2021.10.06
Time: 00:57:14
Engine speed: 0.00 /min
Normed load value: 0.0 %
VCDS
Self-Diagnosis Log
Saturday,09,October,2021,12:25:03:00006
Page 2
VIN: WVWZZZ3CZ------ License Plate:
Vehicle speed: 0 km/h
Coolant temperature: 29 °C
Intake air temperature: 22 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.860 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
Readiness: 0 0 0 0 X
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AF HW: 3Q0 907 379 F
Component: ESC H42 0625
Revision: 00000000 Serial number: 63504000002249
Coding: 0FEC6A8F34200------041C549F0562CD0E0608292F10040F078C002
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 7EF348FAE1F773B46A-802A
1 Fault Found:
4255 - Internal Fault
B200F F0 [137] - Unknown Error Elaboration
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Date: 2021.10.06
Time: 00:56:23
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 H HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0053
Revision: -------- Serial number: 39391433806290
Coding: 0071051001
Shop #: WSC 00028 028 00023
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 408FF602DB83C54458-8014
1 Fault Found:
13637426 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
VCDS
Self-Diagnosis Log
Page 5
VIN: WVWZZZ3CZF------ License Plate:
Fault Frequency: 1
Reset counter: 166
Mileage: 195122 km
Date: 2021.10.06
Time: 00:55:39
Errors:
Revision: B5X21---
1 Fault Found:
17158 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 195122 km
Date: 2021.10.06
Time: 00:57:14
VCDS
Self-Diagnosis Log
Page 2
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Date: 2021.10.06
Time: 00:56:23
Coding: 0071051001
1 Fault Found:
13637426 - Databus
Freeze Frame:
Fault Priority: 6
VCDS
Self-Diagnosis Log
Page 5
Fault Frequency: 1
Reset counter: 166
Mileage: 195122 km
Date: 2021.10.06
Time: 00:55:39
