nokivasara
On page 23 there´s some talk about a delayed switch and diodes but I don't understand what they´re talking about Didn´t see a schematic tho..
Read through the thread, it's ALL in here somewhere.. It's a very basic, and simple wiring mod.. If it seems too complicated, then your best bet is to have someone else put it in for you..sullyTDI said:Somebody please post a pic of this, I want to try this but, not sure of what, where, etc is being talked about. On my injector pump, the connector is a black rectangle, that doesn't look like you can to mod it in anyway.
No photos except for diagrams of the way different people hooked up the resistors.TDIJetta99 said:Read through the thread, it's ALL in here somewhere.. It's a very basic, and simple wiring mod.. If it seems too complicated, then your best bet is to have someone else put it in for you..
I got it, I was thinking about the plug on the injection pump, I was like, dang, how is anyone doing this......TDIJetta99 said:the connector you're looking for is a 10 wire connector going to the injection pump. There is only one connector going to the pump. wire positions 1 and 2 are the ones you need to mess with.. You don't mod the connector, just the wiring.. piggy back a wire onto #1, to the resistor, to a small switch, then back to a piggy back connection on #2.. Done. Just remember to flip the switch back off when you turn off the car.. If the switch is on with the key on, engine off it will toss codes for the quantity adjuster..
Live4SPD,
The 10-pin harness is almost directly behind the oil filter cartridge, when facing the engine from the front of the car.
The pin #'s are clearly labeled on both sides of the harness...
Nope, this is a "fool the engine management computer" mod, and the AAZ has no computer.KADOOMENT95 said:Just out of curiousity...does anyone know if this works on the AAZ engine?
You have to have the switch w/ resistor wired so that with the switch off the signal is still going through the IP. Sounds like you have the IP eliminated from the circuit with the switch off which is giving you the problem you describe.PaPa Bulldog said:I did the evry mod, and have one problem. I wired the switch in series with pin 2 + 3. Now when I switch off the mod it either kills the motor if I'm not moving or if I'm going down the road there is no throttle. So basically it's on or nothing Should I move the switch to pin 3 and one end of the resistor??? I want to be able to drive with or with out even though I know I will always be into the throttle. I thank anyone who has suggestions
Papa Bulldog
brightsideteeem said:hey im new here
i found this via the UK seatcupra website, and have been looking though all the info for a few days.
Does anybody happen to have a photo of how they did theres?
I have a 1K Potentiometer, like 10m of wire, and a red LED.
Do i need anything else, how do you make them turn on and off? This is where im getting confused.
Any help would be fantastic as im getting a headache over this, so I would be very grateful
thanks
rob
OK, good to know. Thanks a lot.Vince Waldon said:Nope, this is a "fool the engine management computer" mod, and the AAZ has no computer.
