So I have been convinced to go to a 2 micron cat filter at my next change but I had a question about the thermal t. I know that alot of older cummins just cap off the return line and feed the return from the ip back into the primary filter 2nd inlet to heat the fuel coming in. Has anyone set up there filter setup like this or would I be better off bypassing the thermo t and taking it straight back to the tank return? I would also be running a water seporator pre primary filter.
