Chungeoisie
I'm working on a Ford Ranger TDI swap project. That's still in the planning stages, but I have secured a junkyard ALH from a 2000 Beetle. Right now my target is around 300hp and 400lbft, and if my understanding is correct, 200hp or 300lbft is around the limit of when you start to risk bending a rod. I really don't want that to happen, so I want to make the engine built and I have a few questions.
I'm considering having it bored to 81mm to make a 2.0L ALH. Will these rods https://www.cascadegerman.com/product/forged-rod-set-1-9-ve/ and pistons https://www.cascadegerman.com/product/81mmpistons/ work with the stock crankshaft? Also which bearings should I get?
Currently it has a 2 hole head gasket. I know I'll have to use a BHW head gasket but I'm not sure how to determine what thickness. I'm also planning to use either a stage 2 or a stage 3 colt camshaft and want to avoid valve piston contact. I've also heard with higher levels of boost you might want to lower compression ratio to avoid lifting the head.
For fuel and air I'm going to get .310 nozzles and a GTD2060vz turbocharger. Along with the camshaft, will that reach my target or will I need to port the head or consider other power mods?
Will shortened PD150 head bolts be sufficient for 36psi boost, or do I need to go with the ARP head studs?
Any help would be greatly appreciated.
