buyingconstant7
So in Calgary it's about -17c(1F), and we have a heated shop THANK GOD! So my sister has a 2006 Jetta TDI with 360,000km and it had been sitting in the snow and cold for a few days. I fired it up(glow plug light went out suspiciously fast, it was on for about 3 seconds) to move it a few hundred feet into our shop, it started a bit hard but nothing unusual. I let it idle for about 3 minutes, drove the car about 200 feet, left it in first gear, and the engine stalled. Turned ignition off, recycle the glowplugs, went out in 3 seconds, tried to start it and it turned over for a bit at normal speed, but didn't fire. About 5 seconds of cranking in, it's like the starter developed a dead spot or something because it would crank fast for half a second, and then slow down and almost not turn the engine over at all, and repeat. I had to get our HD Ram Cummins to boost it(still wouldn't crank fast enough until it was hooked up for 5 minutes), it finally fired and performed fine after that. Took it for a drive, and it was fine. No codes or anything. Fuel filter was changed recently, battery replaced last year with a good high CCA one, and I'm sure it's not fuel gelling since Canadian fuel stations are good about that and it had been filled up 3 days before this. Any ideas?
