BeetleDragon737
Hello all,
My fuel economy had dropped off pretty dramatically over the past couple months, and brakes were my first step in diagnosis. It appears that all my brakes are dragging a little. Wheels don't rotate freely when on jacks and rotors are hot after a drive. My pads are wearing evenly though. Also, the parking brake disengages all the way.
I'm sorta new to maintenance, so I didn't realize flushing the brake fluid was something that should be done often. I bled one brake about 1.5 years ago, and the fluid was somewhere between black and dark green. Time constraints prevented me from doing the rest at the time, and I just forgot about it.
What has potentially been damaged? Would just flushing the fluid accomplish anything at this point? Should I just go ahead and replace the brake lines and all my calipers due to likely corrosion of the pistons? Is there any way to check whether I've messed up the ABS? The fluid in my brake reservoir is clear & green.
Also, turning the front wheels turns gears in the transmission too - how freely should the front wheels spin?
Thanks for any help.
