This.Lots of people don't hook up the water lines, but I think that's probably just because they're being lazy. In a journal bearing turbo, the high oil flow is used for both cooling and lubrication of the CHRA. A BB turbo requires an oil restrictor and therefore there is very little oil in the cartridge. Its function is only to lubricate not to cool. If oil gets too hot it starts to break down and can coke up the bearings. The water jacket around the CHRA is what keeps the oil cool and while it may not be required, I believe Garrett designed it that way for a reason.
Just my 2 cents!
Adam Davison of Pioneering performance does a vklr cast exhaust manifold so you can fit the gtb2260vklr directly to your pd engine. Saves cutting and welding on to your existing manifold. He also uses Narco for tuning I believe.Wow guys lots of replies and loads of knowledge which is great - what do you mean by VKLR monster PD's, 350hp Turbos??
Would love to do stage 2 turbo system but unfortunately I cant fabricate and I cannot find a clear example of someone else setting this up successfully with everything you need so that I can get pass this onto someone to fabricate my manifold etc. then I can just set it all up myself.
Would love to know if you have any examples I could use?
At this current moment it seems my best bet is to use a ceramic ball bearing gtb2260vlkr with near stock internals and just do afew basic mods like porting, camshaft and some injectors which should support the 300bhp as I will already have the bolt on mods like intercooler, intake and exhaust.
Any last ideas for the current 2260VKLR build idea?
Plus I will keep everyone updated with pictures as the build goes on.
I don’t know why you keep pushing personal preference as gtb2260vk well setup on a flow bench will spool from 1800 rpms and support well over 300 Bhp ! I drove all sorts of turbos, if a gtb2260vk didn’t float your boat then it either wasn’t set up properly or the tune was really, really bad ! I -for once- prefer full boost from 2000 rpms on, it gives me enough time to get all cogs meshed into my gearbox and saves clutch/driveshafts and engine from torque shunts as the hardware reacts a bit faster than I can ! I drive my golf mk2 pd tdi toy at 1.85 bar of boost and it’s scary fast, the driveline has issues putting power on the ground with sticky toyo r888r…300bhp comes at a price. Seems to me you will be more happy with a 230-250bhp build with a slightly smaller turbo
Show me a dyno plot with GTB2260 with full boost at 2000rpm.I don’t know why you keep pushing personal preference as gtb2260vk well setup on a flow bench will spool from 1800 rpms and support well over 300 Bhp ! I drove all sorts of turbos, if a gtb2260vk didn’t float your boat then it either wasn’t set up properly or the tune was really, really bad ! I -for once- prefer full boost from 2000 rpms on, it gives me enough time to get all cogs meshed into my gearbox and saves clutch/driveshafts and engine from torque shunts as the hardware reacts a bit faster than I can ! I drive my golf mk2 pd tdi toy at 1.85 bar of boost and it’s scary fast, the driveline has issues putting power on the ground with sticky toyo r888r…
Do you have 1.85bar at 2000rpm with 6th gear?I don’t know why you keep pushing personal preference as gtb2260vk well setup on a flow bench will spool from 1800 rpms and support well over 300 Bhp ! I drove all sorts of turbos, if a gtb2260vk didn’t float your boat then it either wasn’t set up properly or the tune was really, really bad ! I -for once- prefer full boost from 2000 rpms on, it gives me enough time to get all cogs meshed into my gearbox and saves clutch/driveshafts and engine from torque shunts as the hardware reacts a bit faster than I can ! I drive my golf mk2 pd tdi toy at 1.85 bar of boost and it’s scary fast, the driveline has issues putting power on the ground with sticky toyo r888r…
The op has already a gtb2260vk turbo, all it needs some decent mapping and probably a better clutch ! So let’s let him make do with the hardware he’s already got !Show me a dyno plot with GTB2260 with full boost at 2000rpm.
Talking about personal preference, have you counted how many times you have mentioned the 2260 thelast few weeks on this forum? And your golf, and that your head lifts…
as I have read it he doesn’t have a turbo yet. Do you have a full boost by 2000rpm log to show? No wonder your head is lifting because EMP will be sky high…The op has already a gtb2260vk turbo, all it needs some decent mapping and probably a better clutch ! So let’s let him make do with the hardware he’s already got !
That is only possible with a untuned VNT15, even when these are tuned for more boost torque peak / max boost happens later:you want max torque at 1700-2000 rpms
Okay so I wouldn't actually need to do all the internals if I don tthrash the car and be sensible keeping the power nearer the 250hp mark seen as it will be a daily I can then use a smaller turbo then the 22 so that it has quicker spool up such as a GTD1752VRK or maybe even a like an 18 hybrid that i see alot of so that it reaches max power of around 250hp but also has the benefit of faster max boost. That way could I also keep my PD130 injectors as they're the same as the PD150 I believe so should be good for the 250 mark yes? Or should I get bigger injectors to avoid too much pressure and heat at the 250hp mark.H rods/aftermarket rods are not required at your power target, they are good insurance but not necessary. Polybushing the entire car defeats the goal- cars drive better on polyurethane factory updated bushes from much more powerful models(s3/r32/etc) but that’s just my personal opinion! Also cheap coilovers are wasted on a car unless some expensive Kw or bilstein…a matched set of springs and shocks will handle a lot better !
As for advancing the fueling it works up to a point, you get long duration which means heat and excessive pressure in the pistons- best to get larger nozzles. Stock al pd150 nozzles fuel enough for 250bhp…as for spool, you want max torque at 1700-2000 rpms as it will move the car quick but- moving the torque plot to the right of the graph- will be a lot easier on the driveline ! Basically you start driving the diesel as it will be a petrol car and drop a cog or two when you need to make quick progress !
GTB2056VKLR | 816841-0002 | A6420901886 |
