Gothmolly
I have an older boostvalve which used to do a better job of keeping the spikes down. It's the kind that opens up to send boost back down the vacuum line to push the turbo the other way. Now either the turbo is stuck at a different position, or the valve has crapped out. Getting 1st gear WOT spikes up to around 25. Regardless I'll need a new one.
Can someone recommend a good mechanical boost controller that will keep spikes/max below 20 psi?
