moved2tdi
I have a 2001 NB with 118,000 miles on it and I began getting a blowing (or sucking) sound on acceleration. The sound is pretty loud and mainly present with a load. I can hear it while revving the engine but you can really hear it the loudest when accelerating while driving. The sound starts during acceleration and then ends, it seems to correlate with boost pressure. There is no smoke coming out of the tailpipe and there are no codes from the Vag-Com.
I checked the forums and figured it must be a leak somewhere between the turbo and the EGR but after pressurizing the system with an air compressor I found no leaks.
I took it to the dealer (should have known better) and they said the bearing in the turbo is melted and it is keeping the turbo from spinning. That it was caused because of oil starvation. They said when they checked the oil it was not even on the dipstick. Pay us $2500 and we will fix it. I said go to hell took my car and left.
I checked the oil it was about 1 quart low not empty as they implied. I can also still here the turbo whine on accelerations too. So I hooked up a Vag-Com and checked the specified and actual boost pressures. There is boost pressure but the actual pressure does not get as high as the specified.
I am at a loss and have been searching the forums for 2 days now. Any suggestions, is it the turbo on the way out, a leak in the exaust side of the system, or a leak on the intake side that does not show up unless pressure is greater than 15 pounds? I would hate to spend the money on a turbo if it is not?
