[ QUOTE ]
AutoDiesel said:
[ QUOTE ]
I wrote:
This increase in CO2 is not "natural" - it has never been nearly as high as it is now (at least not for many many millions of years. Back before the algaes and such that eventually turned into petroleum lived, the CO2 levels were much higher - and the planet was MUCH hotter. Those critters took CO2 out of the atmosphere, died, and gradually turned into oil, as the planet cooled due to the decrease in CO2 levels. We're now putting some of that carbon back into the atmosphere).
[/ QUOTE ]
You have to go back more than even a few million years to get the whole picture.
[/ QUOTE ]
How exactly did you translate "many many million" into "a few million"?
[ QUOTE ]
The typical work being performed is very shorted sighted and is relying on very recent data and on modeling that is not very reliable. Go back farther and the true picture comes out.
[/ QUOTE ]
LMAO. Recent data and modeling is FAR FAR more reliable than the long term "data" that goes back hundreds of millions of years. Look at the errors in the calculations of those data - they're enormous.
Still, there's a huge problem with most of this data reconstruction, and trying to infer from that the impact of greenhouse gases - never before has there been ARTIFICIAL (human induced) changes in the atmosphere. Many science-hacks look at the data and say "hey, it looks like the atmospheric carbons levels follow temperature, not the other way around". The answer to that is - well duh! If temperature rises, it affects many other factors that are involved in the carbon cycle, primarily the ocean (and its uptake/intake rates of carbon). Temperature rises, and the ocean will release more carbon than it intakes, proportional to before the temp rise. So yes, if temp goes up, atmospheric carbon levels could be expected to go up as well. The problem is, the reverse is also true.
Only ONCE in the earth's history (shouldn't have said "NEVER" a paragraph ago, as there was this one time) was there ever an artificially induced massive increase in greenhouse gases. That was a result of a massive release of methane gas due to plate tectonics, that suddenly increased the atmospheric carbon levels considerably. What happened? Temperatures rose.
It's silly how some people point at much of the carbon/temp data throughout earth's history and make this caim of "atmospheric carbon follows temperature, not the other way around". First, the errors in the times and concentrations are considerable - more than enough to swing which one follows which. Further, only once before was there ever an incident that would have had a sudden abnormal increase in atmospheric carbon levels similar to what we're doing now. And in that case, temperatures did rise considerably.
The oil-PACs in particular, but also many legitimate scientitsts who make the mistake of taking a very myopic view of the climate, make this same mistake. If you look at the silly co2science.org website, you'll see plenty of articles where they do this same thing over and over again - claiming that greenhouse gases have no impact since they clearly aren't the leading factor in the causing of most of earth's climate changes in the past (warming and cooling periods). Someone just needs to smack them and say "well, duh!". There was nothing that would have created a major shift in atmospheric carbon levels to give it any chance to be the initiating factor for global climate trends. Dinosaurs weren't driving around in giant SUVs. Atmospheric carbon levels were completely dependent on the carbon cycle until we came along (with the exception of that one massive methane release, which did result in warming). Why SHOULD geologic records show any instance in which changes in atmospheric carbon levels PRECEDED climate changes? There was nothing to initiate any drastic (non-carbon cycle related) atmospheric carbon change. Until us.
[ QUOTE ]
Seashells Say Earth Temperatures Driven By Cosmic Rays, Not CO2
(snip)
In a unique, cross-disciplinary study recently published by the Geophysical Society of America, Veizer and Shaviv conclude that 75 percent of the earth's temperature variability in the past 500 million years is due to changes in our bombardment by cosmic rays as we pass in and out of galactic spiral arms.
[/ QUOTE ]
75% is a high estimate, but it does have a significant impact.
[ QUOTE ]
In fact, CO2 levels have been as much as 18 times higher than today during the Veizer temperature record.
The earth's CO2 levels were 10 times higher than today's during the frigid Ordovician glacial period about 440 million years ago.
[/ QUOTE ]
See, this is why all of the good climate research groups are extremely interdisciplinary, including space physicists, astrophysicists (there is a big difference), geologists, biologists, marine biologists, etc. etc.. Our sun was a LOT cooler back then, when the earth was young. They're essentially making this argument:
I measured the temperature in my car today with the windows down, and it was 90 degrees F. Yet several months ago, I measured the temperature in my car with all the windows all the way up, and it was only 45 degrees F. So clearly the windows (level of greenhouse gases) have no, or extremely little impact on the temperature in my car.
And ignoring the fact that several months ago it was winter, so there was far less energy from the sun hitting my car. Around 500 million years ago, the sun was putting out something like 25% less energy.
Additionally, the amount of landmass, the level of the sea, height of landmass, and many many other factors have a huge bearing on the temperature. Normally, in science, if you want to determine the impact of one factor, you keep all other factors constant, and only vary that one factor. This is the problem we run into in reconstructing the past of the earth to learn about the climate - essentially every factor changes, so you can't properly evalute the impact of one factor by just comparing two different data points and ignoring all other factors. Yet that's what most/all of the "there is no greenhouse effect" folk do.
Yup, at times in the past, there have been much higher levels of atmospheric carbon, and in some of those times, it was colder than it is now. The problem is, there was also less solar output, along with many other variables that impact the climate (including cosmic rays, and especially the water topography of the earth). If you notice it's colder in December in my car despite having the windows rolled up, will you conclude that the windows being up or down has no impact on the temperature in the car? If not, then why do you fall for the "scientists" who use that same logic when discussing the global climate?
[ QUOTE ]
Human CO2 releases, moreover, make up only about 3 percent of the natural carbon cycle.
[/ QUOTE ]
Yup. Each year, at this point. The earth's carbon cycle had gotten to the point of being nicely balanced. Carbon uptake and carbon release each year is huge, I think something on the order of 400 gigatons (can't remember exactly right now, but I think it's somewhere around there). But it's perfectly balanced. With our release, it no longer is. That completely throws things out of whack. 3% sounds small, but it has a HUGE impact on atmospheric carbon levels over time. At the present rate, we'll have doubled the "baseline" (pre-Industrial) levels in something like another 30-40 years.
The global carbon cycle is normally balanced, so that atmospheric carbon levels stay the same. That's one of the biggest factors that allowed life to develop on earth, while it couldn't on our neighboring planets (may have tried starting on one, but failed). One neighbor lost its atmosphere completely, in large part due to the intake of carbon being far greater than the release (no volcanic activity, etc.), while the other had no means of taking in carbon, so no cycle could start (and therefore it's atmosphere is primarily carbon dioxide).
Atmospheric carbon levels have varied considerably over the past half billion years, and largely in response to other factors (since there weren't humans around to initiate the change). But, other factors varied as well. Taking a geologic timescale look at the earth, and keeping an eye on the future, the planet is in somewhat of a quagmire. About as far back as our "data" goes, atmospheric carbon levels were much higher. But, solar output was much lower, and many other factors varied as well, keeping temperatures from being too high for life to continue flourishing. The sun has been, and will continue to get hotter. Fortunately, atmospheric carbon levels are lower, which should help the planet from retaining too much of that extra heat the sun puts out. The problem is, we're raising those atmospheric CO2 levels back up.
[ QUOTE ]
Iceberg debris from the floor of the North Atlantic says we've had nine moderate global warmings and coolings over the last 12,000 years, in a 1500 year cycle that coincides exactly with a cycle in the magnetic activity of the sun. Veizer and Shaviv say three-fourths of the earth's temperature change is driven by cosmic rays from around the galaxy. Neither study finds much impact on the earth's temperatures from CO2 changes.
[/ QUOTE ]
Well duh! Let's see, there weren't dinosaurs or protozoa around causing massive changes in atmospheric CO2 levels, and we claim it's a big finding that changes in atmospheric CO2 weren't the leading factor in climatic changes in the past? Quick, publish those results! Someone might find them slightly meaningful! But probably no real scientists. /images/graemlins/smile.gif
Here's some reading you should do:
http://calspace.ucsd.edu/virtualmuseum/climatechange2/07_1.shtml
http://www.doc.mmu.ac.uk/aric/eae/Climate_Change/Older/Palaeoclimate_Change.html
The big factor the "I like CO2" folk ignore is the fact that there was no possible way atmospheric carbon could have POSSIBLY been the initiating factor in climate change in earth's history, since there was nothing going around doing anything that would cause a sudden surge or drop in atmospheric carbon. So of course if you look at geologic records, it will indicate that atmospheric carbon was not the biggest factor. There's no way it could have been. The ONLY time it had the opportunity to be the initiator of climate change was the case I mentioned previously of the massive methane release (can't remember when it was offhand, somewhere in the 50-100 million years ago range if I remember correctly), which DID trigger a large temperature increase. Other than that, the only other case of an artificial (i.e. not induced by other climatological changes that preceded it) change in atmospheric carbon is the one we're causing now. But, we KNOW that atmospheric carbon (and other greenhouse gases) play a HUGE role in determining how much heat the earth (or any other planet) retains, after receiving it from its sun. We're now changing those levels artificially, and at the same time as the sun is INCREASING its output. (whereas when you look back in time, CO2 increased at times, but the sun was colder)
[ QUOTE ]
How do you explain 10 times higher CO2 in a glacial period?!?!
[/ QUOTE ]
Read above. Colder sun, and many other factors. How do you explain that the interior of your car can be colder at one time with the windows rolled all the way up, yet warmer at another time with the windows down?
[ QUOTE ]
[ QUOTE ]
The problem is this - we KNOW that dumping vast amounts of CO2 into the atmosphere increases the amount of heat retained by the atmosphere. Not open for debate - known fact.
[/ QUOTE ]
Oh it is, is it?
[/ QUOTE ]
Yes.
[ QUOTE ]
IS THE GREENHOUSE EFFECT AT WORK?
There is evidence that average surface air temperature has increased worldwide by nearly 1 degree F (0.5 C) since 1850. Given the increase of about 25 percent in atmospheric CO2 between the early 1800s and the present, it might be concluded that the greenhouse effect is producing a global warming.
However, there has been little increase in the last 50 years, which raises questions about whether we really have experienced the effect of increasing CO2. The pattern of changing global temperatures suggests that there may be other factors influencing climate.
[/ QUOTE ]
I love how you only quoted the part of their page that doesn't completely contradict what you're trying to claim. /images/graemlins/laugh.gif Here's something to note - that page was written in 1993. Since then, we've had 5 or 6 of the warmest years ever recorded (i.e. since humans started recording temperature).
Also, there was a period in I believe the early '80s when the solar output dropped considerably for a few years or more.
[ QUOTE ]
UN doomsday scenario unfounded, report's lead author asserts
"The world is in much better shape than this doomsday scenario paints," Christy told the British journalist, adding: "There were 245 different results in that report, and this was the worst-case scenario. It's the one that's not going to happen. It was the extreme case of all the different things that can make the world warm."
So the lead authur in the last IPCC assessment doesn't even beleive in the assessment.
Put some spin on that one, bubba!
[/ QUOTE ]
You're the one putting spin on it - Christy rightly feels the UN took the worst case scenario as means of making the problem appear as bad as possible. However, Christy DOES feel the addition of CO2 to the atmosphere will lead to warming - just not as much as the worst-case scenario the UN chose to focus on predicts. The worst-case scenario predicts almost a 6 degree Celsius increase in temperature through the 21st century - double what the previous report (which Christy DID agree with) predicted.
To claim that because he disagrees with the worst-case scenario that the UN focuses on means that the greenhouse effect isn't real would be a great spin job.
Regardless of whether you "believe" in the greenhouse effect or not, the biggest reason for using biodiesel should still be the economic and strategic reasons. I'm concerned about CO2 buildup, but it's never been my primary reason for using biodiesel.
