diesel4ever
A little bit loud with 3" exhaust straight through, but my son likes it. It will be his car anyway.
can you explain the reason you would want to downgrade from a stg3 to a stg2 cam?You've pretty much done what I'm trying to do with my 2dr. I've got the 6spd sitting in the garage along with a Passenger Performance dp and a PD150 manifold and EGR. 1856 and Eurojet FMIC have been installed for several years. I'm leaving the long block stock. Just need to find an 11mm pump and buy some R520's (PP502's in there now) Need to exchange my stg 3 cam for a stg 2 as well. Glad to hear you're happy with it!
I have decided on my project and to go for a 'Big one'. Couldn't allow perfectly good parts to go to a waste so decided to add some more 'good parts' and, hopefully, end up with a nice build.
Here is the list:
Stock block with honed bores to 80mm dia.
Oversized PD150 pistons (80mm)
Rosten Connecting rods,
New 'high flow' head with Colt, stage 2 cam
Kerma K3 hybrid turbo (1856)
Eurojet FMIC (2" piping)
PD130 Intake pipe with PD150 intake manifold along with 'Race pipe'
Race 520 injectors or PP764 stage 2 (TBD)
2.5" or 3" exhaust with high flow cat
6 speed transmission (ERF) with VR6 Axles.
Clutch - TBD
11mm pump with the lift pump.
I hope to push over 200hp and have this ready for TDI fest.
Any other suggestions?
This is supposed to be a daily driver (Two Door Golf MY2000).
